Thinking of changing my brake discs, Front and rear!
What i really need to know is the correct part? I have a 2000 2ltr hdi executive!!
Cheers all
Changing the Discs
Re: Changing the Discs
Nothing special - your local factors should be able to provide you with the correct parts by car reg or description
- DaiRees
- Site Admin
Be sure to change the pads as well, and if you're doing the rears you may as well stick a new set of handbrake shoes in there. Beware the backplates will be rotten!
I found Ebay is a good source for brake bits.
- neildavies
I got a full set of discs, pads and shoes all round for about £120 delivered from ebay, Mintex brakes.
Give yourself a day to get it all done, or do front one day and back another day, like I did.
2007 307cc Sport 2.0 HDi 136
- Site Admin & Mad Biker!
I'd also check how rotten the handbrake cable is while you've got the back end apart.
