Injector noise / chatter (aka why's my HDi so noisy?)
Knowledge Base Articles
Re: Injector noise / chatter
The injectors operate at 80 Volts - this is the only information I can share :lol: :lol:
Makes sense what you're saying Fly - I always likened the noise to pinking myself and a leaky injector would be the cause of this unwanted occurance (performance will be down too).
Trouble with all this is - just about every single HDi out there seems to make this noise :shock:
Hurry to the scrappies, whilst stocks last :lol:
Finally, someone that's actually interested. Well done for finding him young maan :cheesy: so, it looks as though the cause was right, just the reason for it was wrong.
I was meant to be going to talk to a Bosch specialist this week some time but I don't think I'll bother now.
FlySpeck wrote:which can be had cheap from france
Care to elaborate? :?
FlySpeck
Post by FlySpeck »
yah....I seem to have taken the long way round but im happy its 100% the fault of one injector, but I needed to know exactly what was going on and why.
Also learned that the number in the little box is the injector class number, 1 to 4 - which refers to the injectors "squirtyness" (like that word? lol) or rather denotes the stroke CC's from a bosch table at pressure X. The ecu needs to have the same class of injector so it knows how much fuel it is squirting in for each pulse. i.e. an 044 and 062 would both work if they are both class 2 if you were desperate, but be slightly different spray pattern or some other tiny manufacturing difference, as Bosch are anal about having a unique part no for any difference no matter how small, even if its just to denote that it is fitted to a different car even if its the same exact part under the skin.
ah France yeah....it seems these injectors are readily available and much cheaper in the land of wee-wee than here, so I'll try and source a supplier tonight and post the results ;)
2001 406 HDi 90 LX saloon with moon miles...
lofty
2.2 16v
Post by lofty »
Interesting work.
Has anyone been brave enough to find out how much new injectors are each at Peugeot?
I assume they are mechanically easy enough to swap over - do they need anythng else doing, ie electronically with diagnostics?
2001 D9 406 Hdi 90bhp Rapier Estate - Platinum Silver
1999 306 GTi-6 Weekend Toy- Astor Grey
lofty wrote:Has anyone been brave enough to find out how much new injectors are each at Peugeot?
We already know, more or less - you could buy a whole car for that! :(
lofty
2.2 16v
Post by lofty »
Ha ha - you're right.
Approx £283.24 + vat each....
Gulp.
They list 3 different types for the 90 hdi, either stamped with an X Y or Z.
At that price im happy to let it rattle away to itself. LOL :lol:
FlySpeck
Post by FlySpeck »
Ah, yes....pug UK want just under £300 each....**cough cough**
Ebay, from £20 - £45 plus, and no guarantee they are good, as no breaker can test them...my best advice is a scrappy hunt for a cheap set and swap one new one for one old one, cycle all 4 scrappy ones thru the same position until it runs quiet under load. If no change, do the next one etc...
No special conditions for replacing them, just use new copper washers when refitting. If its been running then wait 30 secs after each switch-off till the rail pressure dies away to zero before cracking the fuel couplings open.
and never ever run the engine unless ALL the steel fuel connections are tight again - 24,000 psi leaks can severly injure or blind you. Or worse.
The fuel parts on the system are forged steel to withstand the enormous pressures involved. Your body is mush against such tremendous forces as this badboy can muster, even at idle its around 3000 psi at the injector feed pipes.
When Ford use the pug HDi system (on the TDCi...) they tune each injector to the ecu so they need recoded or it will not run, pug dont do this.
ianr2682
Post by ianr2682 »
Hi, i have been reading this thread as i too was having similar noise symptons on my Relay van 2.0hdi. I have just recently repaired it after cambelt failure. (see other thread)
Anyhow at 2500 rpm i was getting a right clatter from the engine bay. It would start then abruptly stop and then as the revs came back down past 2500 you got a zip type noise.
Turned out it was one of the alternator shield brackets that had broken. Now cable tied in place and no more noise. :)
Locked
