fuel flap
Re: fuel flap
My '98's fine too, but on the '04 it was the first job I had to do. It seemed to me the cable wasn't pulling it far enough so I took a gamble and dismantled the filler - it wasn't there but I made up a slotted tube to take some of the slack out of the cable and it works fine. I mean to have a go at the lever end when the weather clears up but I have a feeling it's going to be a bit of a marathon to get that side of the carpet up.
Re: fuel flap
by next wednesday:Welton wrote:[tempting fate] I'm still on my original 1999 vintage flap/spring combo[/tempting fate]
Welton wrote:[tempted fate] I'm still on my original 1999 vintage flap/spring combo, assissted by mrs wellys ex-peg spring [/tempted fate]
The answers no!
Now whats the question?
Re: fuel flap
Try gripping the pin in the middle with some small grips or pliers & turning it - maybee some WD40.
Then work the pin up, you may need some help & a small screwdriver to get it past the retainer at the top.
- Location: either in my Audi SQ5+, X- trail Aventura or Mini Cooper Cab
Re: fuel flap
Have just repaired mine with the beloved clothes peg
All i used was a small flat blade screw drive to hold bacck the small retaining plastic clip at the top. Then a larger flat blade screw driver at the bottom to push up so peg would fit. Job done 10 min job Many thanks
Re: fuel flap
is there any danger of the spring pushing out the flap too fast and damaging the hinges? whats the cause of this said problem?
Re: fuel flap
As far as im aware i doubt it would damage the hinge. The problem from what i can gather is due to the cable going slack from what i have read. Hence the flap does not open unless you have someone push the flap while you hold the realease in the car or prop the release open with something.
Re: fuel flap
The problem is caused by a bit of plastic breaking of the flap, if you look at my pics you can see where it used to be, at the centre of the hinge.You can see the original spring on the body side of the hinge but once the flap breaks there is nothing for the spring to work against.download/file.php?id=160
Re: fuel flap
Am I the only one here with an original working flap?
Re: fuel flap
Probably, but it's days are numberedWelton wrote:Am I the only one here with an original working flap?
Re: fuel flap
Oh noes.........djp30djp wrote:Probably, but it's days are numberedWelton wrote:Am I the only one here with an original working flap?
- DaiRees
- Site Admin
Re: fuel flap
My flap is fine....Welton wrote:Am I the only one here with an original working flap?
Re: fuel flap
D8 fine, D9 I had to shorten the cable.
Re: fuel flap
'Mechanicaly Sympathetic' keepers you seeDaiRees wrote:My flap is fine....Welton wrote:Am I the only one here with an original working flap?![]()
*pats DaiRees on shoulder*
Re: fuel flap
Ahh you see, we know best
*wonders how long it will be till one of our flaps breaks now*
