thought this list of fuses for the 1996 D8 might come in handy
Dashboard Fuse panel:
FuseNumber - Rating - Functions
1 - 10A - Cigar Lighter
1A --- --- --- --- ---
2 - 5A - Radiator water level, diesel: Water in filter, instrument panel, Power steering
3 --- --- --- ---
4 - 5A - Front left/Right read sidelights, Rheostat lighting
5 - 10A - Headlight adjust control, headlight wash control, dipped beam warning light on dash
6 --- --- --- ---
7 - 20A - Caravan
8 --- SHUNT
9 - 5A - Front right/Left rear sidelights
10 - 30A - Seat Memory power
11 - 30A - Window lift mechanism
12 - 10A - Reversing Lights, Air Con
13 - 30A - Front right seat
14 - 30A - Front left seat
15 - 20A - Central Locking ECU, Fan relay, Bitron ECU, Seat memory ECU
16 --- --- --- --- ---
16A - 10A ? Radio
17 - 10A - Fascia lighting with daylight running light relay connector
18 - 5A - Rear fog lamp
19 - 5A - Passenger compartment switch illumination, fascia illumination
20 - 10A - Left dipped beam
21 - 10A - Compressor cutoff relay, compressors, pressure switch, daylight running lights, fan high speed relay, Air Con control
22 - 20A - Rear wiper, rear wiper timer
23 - 10A - Right dipped beam
24 - 30A - Front wiper control, front wiper timer, front wiper motor, heated screen timer
25 - 7.5A - Radio Memory, CD, Instrument panel analogue clock, coded anti-start, courtesy light
26 - 10A - Hazard warning light switch
27 - 30A - Front one-touch window lift
28 - 10A - Instrument panel, digital clock, rear view mirror control, front one-touch window lift, one-touch window lift ECU, seat memory ECU, Deadlocking ECU, relay for the re-supply to the window lift, sun roof, brake lights
29 - 30A - Front window lift, sun roof
30 - 15A - Front and rear lighting, glove compartment lighting, Lights on buzzer, hazard warning light switch, CD player
Engine Bay fuse panel
Fuse - Rating - Functions
FM1 - 50A - Anti-theft System
FM2 - 50A - Post ignition anti-theft system
FM3 - 50A - 30 fuse box supply
FM4 - 50A - Lighting Control
FM5 - 50A ? ABS
FM6 - 20A/40A - Fan 1
FM7 - 20A/40A - Fan 2
FM8 - 40A - Heated rear screen
The following is for the 2ltr Engine:
Fuse - Rating ? Functions
1 - 7.5A ? Injection ECU
2 --- --- --- --- ---
3 - 25A - ABS
4 - 20A - Engine Running
5 --- --- --- --- ---
6 - 20A - Horn
7 - 15A - Headlight washer timer
8 --- --- --- --- ---
9 - 10A - Lambda Sensor
10 - 10A - Fuel pump
11 --- --- --- --- ---
12 - 10A - Front left fog lamp
13 - 10A - Front right fog lamp
14 - 10A - Left main beam
15 - 10A - Right main beam
List of D8 Fuses
Re: Something to add to the knowledge base
Does any want to add this to the knowledge base then?
Or did I go to that effort for bugger all
- Site Admin & Mad Biker!
I shall move it over now!
