used 406 diesel ?
used 406 diesel ?
i have saved a little money and really want a 406 diesel estate . could somebody please advise me which older models are best as i have maybe £700 only to spend .
- Site Admin & Mad Biker!
Re: used 406 diesel ?
Welcome in Tristan!
Keep an eye on ebay for bargains, the available diesel engines are the 1.9 & 2.1.
1.9 for simplicity (and it runs on chip fat), 2.1 for powah
Yep 86p a ltr fuel when bought at Macro in 20 ltr containers, just pour it into your tank.steve_earwig wrote:1.9 for simplicity (and it runs on chip fat), 2.1 for powah
For even cheaper fuel ask local restaurants for there used oil and properly filter it. Fuel for next to nothing, if you prepared to do some leg work.
Vehicles I own:-
Vehicles I own:-
whats the correct way of filtering WVO properly ?? does waste oil need and additives before you put it in the tank,, ??
This is all I do:-Gary406 wrote:whats the correct way of filtering WVO properly ?? does waste oil need and additives before you put it in the tank,, ??
Collect Waste Veg Oil
Let it settle at ambient temperature, minimum 2 wks
Pour good top oil into a 120 ltr container, stop pouring when oil becomes cloudy
Filter good oil thru a 10 and 1 micron filter into a 20 ltr cubee while adding 10% Petrol
Shake cubee and pour into car
Vehicles I own:-
Vehicles I own:-
10% petrol ?
whats that for ?
wont petrol in a diesel engine knack it up ?
whats that for ?
In this weather you can add upto 15% Petrol, it helps keep the Veg Oil thin. You would need to add 3 times that of Diesel to do the same job.
Petrol in a Diesel is fine, most cars it says in the handbook you can add a percentage of Petrol in cold weather.
Vehicles I own:-
Vehicles I own:-
