hi! new member turbo issues
hi all, ive just swapped my 306gti6 for a 406 turbo (petrol) the car runs fine no smoke, sounds sweet but ive got no turbo at all. can anyone help me?? any suggestions would be great.
Re: hi! new member turbo issues
Hi & welcome to the forum
(madhouse)
Your car could be three or four things,
1. electro valve found on the bulkhead somewhere failed or faulty.
2. vac pipe leak / split.
3. actuator failed.
4. seized turbo
, not unheard of on these cars.
If you can take off the inlet pipe on the turbo & grab the impeller shaft with your thumb & forfinger then try & spin it this'll tell you if it's seized or not
All the best with the new mota DDD.
3. actuator failed.
4. seized turbo
Last edited by dirtydirtydiesel on Wed Jan 22, 2014 9:24 pm, edited 1 time in total.
2006 BMW e61 535d m-sport
run's for cover
Thanks for your help! Did what you said and it turns out turbo is seized solid. Time for a big tear down.
Sent from my iPhone using Tapatalk
Sorry to hear that Joeboy
, best of luck with the project
DDD
run's for cover
