Thought I'd finally register after buying a D8 Coupe last year. It's currently on axle stands so I thought I'd read other peoples tales of woe to cheer me up
I've just spent two weeks trying to get a front brake hose that actually fitted, 3 manufacturers later and I gave up and went to Pug...
Now one of the captive nuts for the subframe is spinning in the chassis leg
PhillipM wrote:Now one of the captive nuts for the subframe is spinning in the chassis leg
I seem to remember something similar happening to mjb's coupe, he had to get someone out to cut a hole in the chassis rail, weld the nut solid and weld the hole back up again
On a 20/20 hindsight note - if anyone else is having issues with one of the bolts (the other 3 came out easily), then I know it sounds harsh, but I'd go straight ahead and drill a small hole in the chassis leg by the nut and fill it full of penetrating oil first - you can always put a rubber bung in the hole after if you don't want to weld it up. It's a much neater solution than having to cut a flap open to weld the captive nut back in....
Hi, welcome across to this forum. The car looks nice, how are you getting on with the front caliper springs?
Do you still want to sell the car..???
2003 2.2hdi estate - mine 1998 Volvo 940 auto estate - also mine 2019 Citroen C3 something - the wife's PP2000 user, can help with faults / diagnostics in the Bournemouth area.
Turns out you don't need to cut a hole in the leg at all to reattache the nut, in fact, if you're lucky you might be able to wedge the nut with a bar or similar, I've still had to weld mine mind is it's REALLY stuck
