Hello 1st time 406 owner
ajax2061
Post by ajax2061 »
Hello brought a 406 2002 hdi 110 last month and wanted to ask a question
The lights and indicator stalk is really lose so looked on ebay for a replacement but there seam's yo be a few different types, is there anyway to know which type to get without taking the steering wheel off ?
Re: Hello 1st time 406 owner
Hi there. I'm afraid on a 2002 that's probably going to be com2000 :(
ajax2061 wrote: Thu Apr 11, 2019 1:56 am taking the steering wheel off
I think you figured that one out already.
6242 30 VALEO - W/O REAR SCREEN WASH WIPE AND WITHOUT ELECTRONIC STABILITY PROGRAM
6242 H6 DELPHI - W/O REAR SCREEN WASH WIPE AND ELECTRONIC STABILITY PROGRAM
6242 C2 DELPHI - REAR SCREEN WIPER AND WITHOUT ELECTRONIC STABILITY PROGRAM
6242 C6 DELPHI - REAR SCREEN WIPER AND ELECTRONIC STABILITY PROGRAM
It can be an expensive fix, and other second hand Comms will be in similar condition.
As Steve says above, despite numerous arguments over part numbers, I think there are only 6 variations of Comms unit - as long as the functions are the same ( front fogs, rear wiper, auto lights etc ) then it should be okay to swap. It also needs to be a Comms 2000 - not a later model.
It's relatively straightforward, but can be tricky first time.
Alternatively, if you don't need the car for a while, it can be removed and sent to a guy called Graham Hall for repair - costs about £40.
He can be found on eBay ( has a mobile number as his user name ) on Facebook, or on Peugeotforum as user 'trustme'
Hope this helps.
ajax2061
Post by ajax2061 »
Would have to take wheel off then as can not do without the car due to disability, bad enough to have to use a stick not bad enough to get full mobility
dirtydirtydiesel
Post by dirtydirtydiesel »
Yes the wheel has to come off.
Alternatively you can drive your car to Graham, he does a while you wait service :)
If your paying a garage to fit a new com's unit, probably going to be north of £300.00 fitted :(
If you are local to Bournemouth I'm happy to have a look at it for you..
In the meantime you can shove a dishwashing sponge into the cowling around the stalk to keep it from flopping around....
WillNZ
Post by WillNZ »
Post your vin number then we can look up your build spec, this will tell us what comms unit you should have.
Serial 406hdi licker :cheesy:
ajax2061
Post by ajax2061 »
Sounds like it is going to be one of these two
Vin number is VF38ERHZF81499087
Service Box shows 6242 C2 for your VIN code
VEHICLE FAMILY 406 (RESTYLING)
SILHOUETTE 5 DOOR ESTATE
TRIM LEVEL LOW - MEDIUM
ENGINE DW10ATED TURBO DIESEL WITHOUT FAP
TRANSMISSION BVM5
PAINT TYPE METALLIC PAINTWORK
BODY COLOUR EZR - PAINT ALUMINIUM GREY
INTERIOR TRIM TYPE VAN VELDE CLOTH "GT"
UPHOLSTERY COLOUR "FX"
GEARBOX (CHARACTERISTICS) ML5C MANUAL GEARBOX
ENGINE (TYPE) EW/DW
OTHER BADGE HDI
ajax2061
Post by ajax2061 »
Thanks for the info :)
Will order one and as long as it not been changed should be all good
rwb
Post by rwb »
Does anybody know how to convert between the XXXX.YY ServiceBox numbers and the actual part numbers (which are the long numbers that begin with a 9)?
This is between the actual manufacturer's part numbers and the ones Pug uses? A lot of suppliers will list both codes (and the same parts other manufacturers use e.g. Fiat)
archangel2
Re: Hello 1st time 406 ownerVINnumber
Post by archangel2 »
VF38BRHYF813298
