New user from Estonia :)
406Break
Re: New user from Estonia :)
Post by 406Break »
steve_earwig wrote:
406Break wrote:Nobody knows why my cars engine is slightly unstable (idle ~735-748 rpm)(It maybe hard to imagine but it sounds, looks and feels)
Lambda probe?
Lambda seemed fine. The funny thing is that Peugeot Estonia has 2 employees who both have the same problem... Engine runs a bit restless...
On city streets 16L/100km fuel consumption
That's appalling! (=17.655058517mpg) Still, it is a petrol :|
On a full tank i can drive for 400-430 km. If I've been on the highway then 500km. Peugeot owners manual says city-11l/100km highway-8 or 9L/100km.
And usually people get better mpg that in the book...
headlights are weak @ night IMO
Are they getting the full 12 volts from the battery? Are they going cloudy??
Their getting the 12V. Maybe its me...
windscreen wipers dont work well @ high speeds :P
Is that when they are working at high speed (as Eoin says, probably the motor) or do they have trouble when the car is going fast? (Weak springs at the bases of the wiper arms)
Wipers pick up air when doing highway speeds. Maybe the springs, might just bee :)
PS: Sorry, I may have problems writing words correctly :P
Peugeot 406 Break - 2.0L - 99kW - EW10J4/RFR - BVM5 - VF38ERFRE80937145
eoin27
The Irish 406 addict
Post by eoin27 »
500km????. Thats 312.5 miles. My tank does 800 miles, that is 1280km. I know mine is a diesel but its still not anywhere near right with yours. Sounds like a serious engine problem.
eoin27 wrote:500km????. Thats 312.5 miles. My tank does 800 miles, that is 1280km. I know mine is a diesel but its still not anywhere near right with yours. Sounds like a serious engine problem.
I'm lucky if I hit 300 miles to 70 litres :shock:
The V6 sounds soooo good though :twisted:
I added another 350 miles to the clock over the weekend (trip from Aberdeen to Glasgow and back), which I did on a full tank of petrol.
406Break
Post by 406Break »
What I remember is when i got the car tested the temp.sensor "told" the ECU that coolant temp is 45*C.
When they measured it by hand then it seemed ok.
(with a tester, set on Ω - electric resistance was somewhere around ~1300Ω, so 90*C)
406Break
Post by 406Break »
BTW the lion is gone because i hit a deer a few months ago :(
Workshop took out a dent in the hood and fitted a new grille... they forgot to glue on the new lion so the gave it separately to me :P
Maybe you should glue the deer on instead :cheesy:
406Break
Post by 406Break »
I'll try to change the lambda sensor, some say that a dirty sensor may not cause a fault code but may increase fuel consumption... Then we will see...
Cause the low MPG thing happened right after the exhaust pipe was broken - then fixed but it may have smoked the sensor :(
406Break
Post by 406Break »
Rear left wheel feels loose, and clonks every time i drive through a pothole...
Might it be the rear stabiliser rod?
406Break
Post by 406Break »
Haven't posted in a while.
Milage in the city is normal ~10.5-11.5l/100km
Highway still sucks, above 8l/100km.
Highway milage may improve after wheel alignment tho...
Bushes and other parts in the front and back axles still need changing before that.
Still a lovely looking and riding car :)
406Break
Post by 406Break »
Also as a side-note. I have had my hand full with this guy(pic)(born 03.06.2013)
He was born just after I got out of the military(was there for 8 months).
Happy daddysboy and a car fanatic :D
