hi all my rear doors are creaking so i need to remove the pins but it has a m6 (10mm head bolt) in 1 half then what looks like a pin. do you just remove the bolt & bray the pin out
thanks in advance
rear door hinge 51 plate
2.0hdi lx 51 plate 90bhp chassis no.VF38BRHYF81371125
Re: rear door hinge 51 plate
whens the last time the door strap was greased ? apply some wd40 to the strap and then some grease.
mine were creaking when i bought them but there not now
cheers gary the doors are a bit better with some grease on the strap. but i still would like any info about the hinges if poss thanks
