How to change fog lamp bulbs
sockpuppet
Post by sockpuppet »
Hi there, how do I change the fog lamp bulbs on my D9? theres a panel below the bumper so i cant get down there. also, do they use the same H7 bulbs that the main beam headlamps require?
406 2.0 HDi Rapier, 2003 plate
rapport25
Re: How to change fog lamp bulbs
Post by rapport25 »
Hi SockPuppet, it's about a 10 min job :D
I always find it easy to jack the car up and remove the front wheel. Then you will need two different type star head fitments. ,I think its a 10 and an 8. Remove the plastic trim from under the fog light housing and on the lower inner wheel arch trim. trim drops down and there you have it foglight housing :mrgreen: Remove the plug then quarter turn bulb holder and thats it.
Also bulbs are H1 fitment in the fogs.
Rappy 8)
