D8 Bump strip removal & Replacement
Posted: Thu Apr 15, 2010 11:29 am
by Roylewaa
Today I set about removing my broken bump strip and replacing it from a one from the scrap yard
Is their a certain way to remove and replace them that dosent break every clip in sight?
I removed 3 from cars breaking in the scrappy and I broke every clip, and then proceeded to break all the clips on mine removing the broken one
Theres now a row of broken clips where my bumpstrip used to be :cry:
cheers for any info
Re: D8 Bump strip removal & Replacement
Posted: Thu Apr 15, 2010 11:48 am
You're best of getting more from Pug, this came up recently and they're pennies.
Posted: Thu Apr 15, 2010 12:55 pm
by barryj75
unclip each end then slide either left or right that how i did mine
Posted: Thu Apr 15, 2010 2:25 pm
by Roylewaa
barryj75 wrote:unclip each end then slide either left or right that how i did mine
Thats what I tried to do but they just kept breaking with bits of plastic flying everywhere :shock:
Theres a Pug dealer 5 mins up the road, il get some more clips
Are they a readily available off the shelf part? or will I have to order and wait
Posted: Thu Apr 15, 2010 3:13 pm
by barryj75
my main dealer said i had to buy new bumper strips as clips come as a complete set one of the lads gave me a hand full and he said they order them in packs of 100 for coppers i try stear clear of main dealer
Posted: Thu Apr 15, 2010 3:37 pm
by eoin27
You can push them out from the inside with a long nose pliers to push each side together. I wouldnt bother though its too much hassle. Its part number 8565.34
Posted: Thu Apr 15, 2010 4:16 pm
by Roylewaa
thanks for that, you beat me to it
my next question was if anyone had the part number :D
Posted: Thu Apr 15, 2010 4:56 pm
by plod
I bought some the other day, 14p+vat each, although my stelaer had to order them in - took 2 days
Posted: Fri Apr 16, 2010 11:52 am
by Roylewaa
Just rany my local dealer, they have 16 in stock so popping over to get some, I just need 5, but will get probably 10 just to be on the safe side, As I can be a bit rough sometimes :D
Posted: Fri Apr 16, 2010 2:21 pm
by plod
my stealer had 14 in stock but needed 24, - 7 for each front and 5 each rear door so had to get them to get some in so had 30 instead.
It's like the ones that hold the sill rubber on, I got half a dozen extra of those just in case
Posted: Fri Apr 16, 2010 3:20 pm
by eoin27
Remember, dont put them into the door first. Slide them into the sill guard first.
Posted: Fri Apr 16, 2010 8:42 pm
by Roylewaa
I got some this afternoon
Yes, I slid them on the bump strip before I clipped it on
Cheers for all the info chaps
Lovin' this forum :D
Posted: Fri Apr 23, 2010 2:57 pm
by gumby6371
Recently had cause to change mine and thought I'd add a little note to this post, if your stripping a replacement from a car at the breakers make sure you remove the strip from the hinge side of the door first. I snapped the 'L' clip on the first trim i tried to remove (luckily nobody saw and they had a few D8's in). ease the starlock washer off with a screwdriver, no real choice but to snap the clips then slide the 'L' clip bit out of the door.
