removing headlights on a d8
chrisfinlay
Post by chrisfinlay »
Hi all,
searched for this but could only find info on d9's (mind you, it IS 745 am so a little bitslow this morning!)
I have a dipped headlight out on my driver's side cluster - the side lights and full beam are working fine, so I reckon it's just t'bulb. I had a go at getting it out last night in the pissing rain, but I only found one bolt/screw/thingy holding it in place at the top - but after removing it I still couldn't take the cluster out. Are there more, or is there a trick?
1999 (D8) 406, 2.0L HDi.
Re: removing headlights on a d8
I'm a little confused, are you trying to change the bulb or the whole headlight unit?
i assume the headlights are mounted the same in d8/d9 so youll need to take off the grille, then youll see another bolt, then there is one more holding the light onto the wing, hard to get at but once its turning it comes out easy, just dont drop it. So thats it 3 bolts in total, and it comes out
chrisfinlay
I'm trying to change the bulb - I am under the impression I have to remove the unit to access it?
chrisfinlay
406executiveHDI wrote:i assume the headlights are mounted the same in d8/d9 so youll need to take off the grille, then youll see another bolt, then there is one more holding the light onto the wing, hard to get at but once its turning it comes out easy, just dont drop it. So thats it 3 bolts in total, and it comes out
There's no grille-side bolt, that side came loose easily, but it was wing side that stayed firm.
get a wee socket ratchet in there, it needs a good pull, i did it, and chafed my hand on the wing cut it right open not nice, so be careful
chrisfinlay wrote:I'm trying to change the bulb - I am under the impression I have to remove the unit to access it?
DO NOT remove the whole light to change a bulb :shock: :shock: :shock:
simply clip of the cover on the back of the light, access the bulbs there
it takes all of 2 minutes to change a bulb 8)
ah right yes thats right bulbs can be changed without taking all out
It's a bit of a squeeze but they aint no Renault. Pay attention to which way up the bulb went 'cos it'll make it easier to slot it back and expect the clip that holds the cover on to break off - nothing you can do about that, the plastic goes brittle with age.
chrisfinlay
thanks for the help folks - replaced with nothing broken. £9 f*cking 50 for a bulb though...
As an aside, my drivers side dipped bulb doesnt have the plastic cover on it that's covering the rest of the bulbs... must have been replaced a few times before! :P
£9.50 for a bulb :shock: :shock: :shock:
you can get a full set for that if you shop round, i bought mine off amazon 1 year ago, xenon look-a-like £12 full set including fog lights ,
4 H7's , 2 H1's and 2 501 side light bulbs, yah all £12 and there still working fine :cheesy:
just be thankful you havent got a big ass megane
Archangel
Post by Archangel »
chrisfinlay wrote:thanks for the help folks - replaced with nothing broken. £9 f*cking 50 for a bulb though...
Jeez Chris you been had ! , only cost me £4.89 for a set of 2 bulbs and they were Xenon bulbs
Replacement !
I once paid £10 for a main beam bulb, the brand for it was ring and it worked.
