Removing wiper arms...
- STALLED
- The moderator down under
Thought i'd give it a test run, before I'm going to paint them later in the week (as it's about to piss down)...
But how do you physically remove the wiper arms - I got the main bolt off and hit it with some WD40 to "loosen" it up to no avail...I don't want to break the windscreen like another 406oc'er did a while back!
Cheers,
Joel
Cheers,
Joel
Re: Removing wiper arms...
I remember it took a lot of wd40 and tapping with a hammer plus a bit of brute strength
to get mine off ,I believe there is a tool for the purpose.
- Site Admin & Mad Biker!
Something like a balljoint splitter should do it, either that or one of those crows foot tap spanners.
i just removed the bolt them twisted the bloody thing off,
grinding most of the teeth off but once bolted back they still work a treat
- DaiRees
- Site Admin
Didn't Jasper say to loosen the nut then press down on the hinge bit of the arm?
they are on a taper like a ball joint you need a puller to do the job really if you check e bay they are about 7 pounds.STALLED wrote:Thought i'd give it a test run, before I'm going to paint them later in the week (as it's about to piss down)...
Cheers,
Joel
any other way just damages something in my experince.
- waue1978
- HDi don't believe it!
Is it a similar idea to the way the steering wheel is fitted? They're a pain too, but only really the first time. Once you've heaved & squeezed the original one off, you find that the replacement slides out with relative ease the next time you do it.
Cars are so much like women it's unreal...
- 406Iain
Mine come off easy.Take the nut off,activate the wipers and the spindle works its way loose and I can just wiggle the wiper arms off.
407 GT multimedia
- plod
mmmm, might try that406Iain wrote:Mine come off easy.Take the nut off,activate the wipers and the spindle works its way loose and I can just wiggle the wiper arms off.
1999 D8.5 HDi GLX - Sold
Bring back my 406
- STALLED
FFS - they are stuck hard! Took ages to get them off - then I managed to do a typical DIY stuff up by putting the wiper arms the wrong side!
Managed to strip the teeth off the spindles (nice work...) but they seem to work fine if you tension up the bolt nice and tight!
ive got the primer, and new black paint for mine and put conventional bosch wipers on them so they will look good when removed.
