Posts: 5315 Joined: Sun Mar 28, 2010 9:56 pm
Post
by Gary406 » Thu Jan 13, 2011 12:11 pm
found another little leak with door cards being off atm
the rear quater window seal , water running on insode of doorcard and down into inside of car
Posts: 9656 Joined: Tue Jun 01, 2010 5:42 pm
Post
by FarmerPug » Thu Jan 13, 2011 11:46 pm
have you removed the sealing sheets? Thats why mine leaked because when i added the new door handles i was a bit rough with them, i resealed them up, but i really want to buy new ones as the back one squeaks a bit.
Post
by Gary406 » Fri Jan 14, 2011 7:20 pm
its leaking from the quater glass seal at the bottom .
Post
by Gary406 » Fri Jan 14, 2011 7:25 pm
there is 2 metal brackets that hold the door card up, the inner 1 is totally full of rust were water has been seeping over it into car , so ive cut it off and put sum tigerseal under rubber
Post
by FarmerPug » Sat Jan 15, 2011 2:53 am
pictures will be needed.
