I've just caught my NEW rubber door sill trim with my shoe and bust 3 of the little trim clips off
The whole trim is brand new, but can you just get the clips???
They look the weakest silly clips I've ever seen
Stupid door rubber trim on sills
- neildavies
Typicalminiman wrote:6p each!!! What a fortune!
I stuck mine on with a product called "tigerseal". Its like "no more nails" for car bodywork. Mine have never moved since, and I catch it EVERY time.
sill strips
I found a wonderfull fix it's called velcro . if you knock it loose just stick it back on (works great).
Put one half on the sill and the other strip on the rubber strip problem solved.
