As title, my estate came with a towbar. In the boot. And no mounting bolts.
Soooo, i need to know the size of the bolts that go into the rear crossmember and the chassis rail fittings and what strength they are (high tensile or standard, etc)
Cheers.
Towbar Mounting Bolts, size?
2.1td exec estate.
Re: Towbar Mounting Bolts, size?
Hi, do you have the clip in captive nuts that go in the chassis legs or nothing at all? I would have expected these to be a relative pain to get hold of. All I can suggest is you try contacting a towbar company to see if they can supply you with a new fitting kit short of that my old one went for £40 on ebay...
