İLK ÖNCE HAVALANDIRMA IZGARALARININ TEMİZLİĞİ İLE BAŞLADIM...
atas VİNET ve atas PLAK 2r
1 AYDAN FAZLA DURAN PASPAS KAĞITLARI...
İÇ TEMİZLİK.
DÖŞEMELERE TURTLE WAX - NEW CAR ARAÇ KOKUSU
TORPİDO'YA ve PLASTİK AKSAMLARA atas PLAK 2r
ARKA TARAF ;
TAVAN ;
DERİLERE TURTLE WAX C&C GEÇTİM ve ARDINDAN DERİLERİN YUMUŞAMASI.
JANT TEMİZLİĞİ ;
MOTOR TEMİZLİĞİ ;
YAĞ ÇÖZÜCÜ MOTOR TEMİZLEYİCİ SIKIP MOTORA İŞLEMESİNİ BEKLEDİM...
SONRA atas VİNET SIKIP FIRÇANIN GİREBİLDİĞİ YERLERE KADAR FIRÇALADIM...
FIRÇALADIKTAN SONRA MOTOR TEMİZLEYİCİ VE VİNETİ BİRAZ BEKLETTİM VE SÜZÜLEREK KİRLERİ ÇÖZMESİNİ SAĞLADIM...
SONRA DURULAMA...
BEZİN GİREBİLDİĞİ YERLERE KADAR KURULADIM...
ARABAYI ÇALIŞTIRIP MOTORUN ISINMASINI VE SU DAMLACIKLARININ KAYBOLMASINI SAĞLADIM...
atas PLAK 2r SIKTIM VE SİLMEDEN KAPUTU KAPATTIM...
10-15 DAKİKA SONRA KAPUTU AÇTIM VE ;
DETAYLAR VE YIKAMA ;
atas VİNET SIKIP FIRÇALADIM.
ÖNCE SU TUTUYORUM...
BU YÜZDEN ÇİFT KOVA :iyi
DURULAMA ve KURULAMA
UBER BLUE DRYİNG TOWEL
SONRA atas HYDROREP (Quik Detailer) GEÇTİM. (Sonax Şişesi İçinde)
PASPAS KAĞITLARI SERİLİR.
406 CLUB :havali
406 - Mini Detailing
Re: 406 - Mini Detailing
I'm shocked!
That must be cleaner that when it left the factory
(I think I've spotted a modified fuel-flap wanger there)
- waue1978
- HDi don't believe it!
Pah, half a job.Mert wrote:ENTER -> http://www.skodaturkey.com/showthread.p ... post279401
Should've done under the engine cover, pop the window trims up to do under them & also under the rubber door seals...
- rwb
This won't end well:
Cunning fuel flap opening spring:
Thats kept clean, what do you use to keep the headlining cleaned?
Thanks, i dirtied my headlining the other week with my hands reaching for the sun visor its been bugging me ever since.
Is the spray called detap, is that a brand name, is there any other name i can use to see it for sale on ebay.
What about seat belts, is there anything good for keeping them clean.
For Roof linings ,
iuse, Stardrops, Mix it too a foam, and clean the cloth with the foam, not the liquid
its under a £1 and is awesome on cleaning interiors and carpets,
you can use it as a degreaser too on car bodywork,
its just with a cream headliner that worries me it could get stained very easy.
if you get stains on the interior, its down too using the water ,
it drys out patchy,
use the foam not the liquid from it,
Stardrops does not stain cloth if used correctly
also if you clean Rooflinings dont wet them or they will sag once theyve dried out,
it drys out patchy,
