Drivers side rear carpet sodden....
dukey406
Post by dukey406 »
Anyone have any pointers on this one, spare tyre well dry, drivers footwell dry as are all the others.
The rear offside footwell carpet is saturated. Door seal seems to be fine and window closes properly ??
Help!
If it aint broke - dont fix it!.....
http://ddukey.deviantart.com/
406 HDI 110 GLX Estate.
Re: Drivers side rear carpet sodden....
Only time this happened to mine was when we were camping & the rain was that torrential it was hitting the car sideways; also the door sill rubbers were hanging off which didn't help!
May also be worth popping the door card off to see if the water shedder has been played with by edward scissorhands.
i also think seal behind the doorcard
remove doorcard and check the door seal behind it is sealed all the way round ....
once you remove doorcard you will notice a sponge type seal all over the door. check the sponge seal is sealed all round and isnt damaged ..
Drive through a car wash
and look in the boot (from inside of car :roll: ) while its being washed :idea:
grasmere59
Post by grasmere59 »
When i had a leak after a repair the garage sprinkled talcum powder around the area,if there is a leak you can see the track the water has taken in the powder.
2012 "62" Yamaha XT1200
1974 "M" Honda CB500/4
1994 "M" Kawasaki Zephyr 1100
1998 "S" Honda XRV 750
