Drivers side rear carpet sodden....
Posted: Mon Dec 12, 2011 10:02 pm
by dukey406
Anyone have any pointers on this one, spare tyre well dry, drivers footwell dry as are all the others.
The rear offside footwell carpet is saturated. Door seal seems to be fine and window closes properly ??
Help!
Re: Drivers side rear carpet sodden....
Posted: Thu Dec 15, 2011 2:41 pm
by teamster1975
Only time this happened to mine was when we were camping & the rain was that torrential it was hitting the car sideways; also the door sill rubbers were hanging off which didn't help!
May also be worth popping the door card off to see if the water shedder has been played with by edward scissorhands.
Posted: Thu Dec 15, 2011 5:40 pm
by Gary406
i also think seal behind the doorcard
remove doorcard and check the door seal behind it is sealed all the way round ....
once you remove doorcard you will notice a sponge type seal all over the door. check the sponge seal is sealed all round and isnt damaged ..
Posted: Thu Dec 15, 2011 5:51 pm
by lozz
Drive through a car wash
and look in the boot (from inside of car
) while its being washed
Posted: Thu Dec 15, 2011 5:55 pm
by grasmere59
When i had a leak after a repair the garage sprinkled talcum powder around the area,if there is a leak you can see the track the water has taken in the powder.
