n/s headlight replacement
wafeeq
1.6 8v
Post by wafeeq »
hi throbley
for my car there was no airbag sensors near the head lights, anyways here's what I did
1- removed the grill
2- located three screws holding the headlights: one on top required a torx key, the other on the side required a 10mm socket with extention and the third was in front behind the grill with an extra long 10 mm screw.
3- disconnect the wires from the headlamp.
4- unscrew the one on the side then the torx up then the long one
5- vois la, just take it off.
anyway if you're concerned about the airbag blowing just disconnect the battery
Good Luck
Malachy
2.2 16v
Re: n/s headlight replacement
Post by Malachy »
this is typical farm yard bs,
the air bags are fired by internal Accelerometers, these measure g forces, you cant just hit a sensor and the airbag will fire off, the sensors will also be no where near the headlight they are integral to the airbag system on most cars.
1996 306cab with a few mods
jameslxdt
Post by jameslxdt »
on a d8 406 the airbag sensor is behind the handbrake
