hi and happy New Year...
the door seals leak! When it rains a lot the carpet is all wet and soon smelly! Does anyone have experience of changing the door seals? Is it easy? Any helpful comments would be appreciated.
Cheers
Marcus
leaking
- DaiRees
- Site Admin
My previous 406 (d8 ) used to leak into the passenger footwell in heavy rain, you could actually see it tricking in over the plastic trim just down by the passenger's left foot. Turns out someone had butchered the polyethene water shedder inside the door
cowboys!
My D8 did that - not pleasant comming back to the car after it has just rained....car fogs up really bad as well because of the heat in Australia!DaiRees wrote:My previous 406 (d8) used to leak into the passenger footwell in heavy rain, you could actually see it tricking in over the plastic trim just down by the passenger's left foot. Turns out someone had butchered the polyethene water shedder inside the doorcowboys!
STALLED wrote:My D8 did that - not pleasant comming back to the car after it has just rained....car fogs up really bad as well because of the heat in Australia!DaiRees wrote:My previous 406 (d8) used to leak into the passenger footwell in heavy rain, you could actually see it tricking in over the plastic trim just down by the passenger's left foot. Turns out someone had butchered the polyethene water shedder inside the doorcowboys!
show-off
but welcome to the site anyway you should fit in fine
