Goood day. Have a 97 estate ,manual rear window regulators. bought a 406 sedan with a blown motor to get the wheels and some other bits .
Do the regulators from a sedan fit the estate?there is a part number on the regulator 9615037580.
Just googled it and it looks like the scrapers here in Sweden show it fitting both ? http://www.bildelsbasen.se/?link=list&s ... 9615037580
Any comments would be appreciated.
window regulators estate
It is not the possession of truth, but the success which attends the seeking after it, that enriches the seeker and brings happiness to him.
Max Planck
Max Planck
Re: window regulators estate
Hi,
It looks like the same part numbers for both saloon and estate, but left and right doors are different:
9223 36 Left
9224 37 Right
Sign up to http://public.servicebox.peugeot.com/ (just make up some details saying you're an independant garage) and you can search their parts database.
9223 36 Left
9224 37 Right
They are the same, just the glass is a different shape. One problem might be if this is an electric regulator as there's a change which is dated 3rd June 1997 (RPO 07511), so if your car and the donor car are either side of this date it might not work. No, I don't know what they changed...
Thanks for the tipDoggy wrote:Hi,
Sign up to http://public.servicebox.peugeot.com/ (just make up some details saying you're an independent garage) and you can search their parts database.
My garage is now called "Pugs på landet" ="pugs in the countryside"
Max Planck
Max Planck
Nope both manual .steve_earwig wrote:They are the same, just the glass is a different shape. One problem might be if this is an electric regulator as there's a change which is dated 3rd June 1997 (RPO 07511), so if your car and the donor car are either side of this date it might not work. No, I don't know what they changed...
Max Planck
Max Planck
Pure class.dadooo wrote:Thanks for the tipDoggy wrote:Hi,
