anyone tried this
Posted: Thu Aug 21, 2014 5:03 pm
by trem1
Re: anyone tried this
Posted: Thu Aug 21, 2014 5:40 pm
by jonsowman
Brave doing it whilst it's still on the car! I'd probably take it off first
Posted: Thu Aug 21, 2014 6:13 pm
by rwb
I think I heard something about peanut butter too.
Posted: Thu Aug 21, 2014 7:34 pm
by MixMan
If you took the trim off, wouldn't the heat make it all curl and distort?
Think he does it on the body to keep it straight.
Should be ok if you keep it moving to avoid hotspots.
....Caveat emptor as they say........
Posted: Fri Aug 22, 2014 8:40 am
I tried Peanut Butter on me bumpers but the neighbours dog kept licking them.............
Posted: Fri Aug 22, 2014 8:43 am
by jonsowman
MixMan wrote:If you took the trim off, wouldn't the heat make it all curl and distort?
Good point, didn't think of that, it might well do. I'd still be scared to try it I think!
Posted: Fri Aug 22, 2014 9:39 am
by trem1
Its a bit extreme for me as well,specially when all thats wrong with mine is one rear corner bump strip is 'slighty' grey compared to the rest.
Posted: Fri Aug 22, 2014 11:33 am
by Rolebama
I am not sure it made all that much difference. A before and after shot from the same angle might be more convincing.
I don't know that taking the mouldings off the car would cause them to warp as some are made of 'memory' plastic. I have seen some returned to shape by warming after a collision when they have been distorted. I don't ever recall them looking any 'shinier/cleaner' though.
Posted: Fri Feb 27, 2015 3:03 pm
by 406Break
It works by melting the plastic(just a little). Silicon from inside the plastic boils to the surface. It's a 1-2 year thing, if not maintained with "black in a flash" or similar bumper care stuff. Did that to my old trusty Renault once. Before and after pics added. Pictures have a few weeks between them
Before:
After:
Anyhuu, because it is "melting" plastic, then don't stay on one spot too long
Posted: Sat Feb 28, 2015 9:03 pm
by lozz
trem1 wrote:Its a bit extreme for me as well,specially when all thats wrong with mine is one rear corner bump strip is 'slighty' grey compared to the rest.
This is what iuse...
http://www.valeterspride.co.uk/1-litre- ... t-84-p.asp
Brilliant stuff. its good on tyres too..stays on for months
Posted: Wed Apr 08, 2015 5:11 pm
by peter64
Welly wrote:I tried Peanut Butter on me bumpers but the neighbours dog kept licking them.............
Posted: Wed Apr 08, 2015 5:26 pm
by KozmoNaut
I've done the heat gun trick on my 406, and it definitely works for a while, until the plastic sustains enough UV damage to fade again.
It's actually quite easy to do, as you can see it working and turning the plastic black again. With good lighting, progress is very obvious. You just have to watch out that it doesn't melt the plastic (so use the lowest heat gun setting that works). On D9s you have to be very careful around the chrome strips, never aim the gun directly at them, as the surface will start melting and bubbling very easily.
