Glass mirror for my 406
rapport25
Location: either in my Audi SQ5+, X- trail Aventura or Mini Cooper Cab
Post by rapport25 »
Any ideas the best place to get a relacement glass from i want the same as standard with blue tint blind spot indicater as its the drivers side thanks. Or is it best to stick to the dealer which i think are around £30?
wes1001
Location: Sticky out bit, right on the tip of Kent, practically in the channel !!
Post by wes1001 »
Halfrauds do a stick on replacement for £6:99 ( which i found out after a poxy porsche took mine out going down a country lane ) or a blind spot one for about £12 i think but they only work if you still have the original glass - albeit probably broken but doesn't matter - and /or backing plate to stick it onto. :cheesy:
ThePrisoner
Post by ThePrisoner »
wes1001 wrote:Halfrauds do a stick on replacement for £6:99 ( which i found out after a poxy porsche took mine out going down a country lane ) or a blind spot one for about £12 i think but they only work if you still have the original glass - albeit probably broken but doesn't matter - and /or backing plate to stick it onto. :cheesy:
Yeah not bad for a cheap replacement, but the quality of the glass cut isn't very good, and if you have heated wing mirrors the stick on ones won't work.
However ideal for if your on a budget, or need to pass an MOT or sell the car. lol
Pris. :cheesy:
rapport25
Post by rapport25 »
I agree they are very cheap looking also mine is heated. Tried hunting one down of e bay with no joy. Paid £41 from a dealer should of been nearly £50.
