How to remove/replace third window on estate/break
Posted: Sat Jan 25, 2020 6:26 am
by Edmond
Hello boy's and gal's...don't know if this belongs here but didn't find anything through search...
Sooo..like it says on the subject, I need to know how to remove/replace third window on 2000 estate/break...
https://ibb.co/SKQTj05
Somebody at construction site broke it...
Thanks in advance...
Re: How to remove/replace third window on estate/break
Posted: Sat Jan 25, 2020 10:34 am
by GingerMagic
Sadly I can't help, it's not something I have tackled before - is there a local window fitter/ windscreen repairs/ autoglass sort of thing nearby, I'm sure they would have the tools, knowledge and experience....
Posted: Sat Jan 25, 2020 10:43 am
by Doggy
Failing that experiment with one in a scrapyard, if you (or they) can get it out in one piece it's worth buying.....
Posted: Sun Jan 26, 2020 9:39 am
by Edmond
That's why I'm asking... Found a scrap yard that has the whole car but I'm interested in how to remove it without breaking it...
Posted: Sun Jan 26, 2020 9:09 pm
by Doggy
Sorrry, I have no idea - but you could practice on the one on the opposite side.....
Posted: Mon Mar 16, 2020 6:12 pm
by dirtydirtydiesel
Bonded in, the same as the windscreen
Not sure how you'll get on with the one in the scrap yard as the seal comes with the glass
& is secured in place with the window mastic.
If you remove the trims from the inside you might be able to cut it out but you'll probably damage the seal.
As ginger say's a autoglass place or bodyshop or main dealer could advise better.
