is my car d8 or d9
Posted: Sun Feb 03, 2008 8:58 pm
by lorus5000
hi i own an R reg 406 1.8glx etaste is this a d8 or a d9..
also i have just bought a donor car for parts, its an R reg v6 3.00 liter estate auto. what is this d8 or d9...
and finally are the parts ie boot, bonnet doors swappable...
thanks for your help, im new here and dont have any knowledge on this..
thanks for your help...
lorus
Re: is my car d8 or d9
Posted: Sun Feb 03, 2008 9:44 pm
by teamster1975
If it's R-reg it is definitely D8; the D9's started coming in on the T plate.
You can certainly swap the bodywork over, just watch for your alignment on the bootlid & doors, mark the body before you unscrew the hinges.
The bootlid is a bitch to line up, I haven't had the bonnet off.
If you're planning on swapping out the front doors be prepared to unthread the loom from the door, but the rear doors are plugged.
Hope this helps!
Edit: Welcome to the club by the way!
Posted: Sun Feb 03, 2008 10:51 pm
by lorus5000
thanks for the quick reply, and thanks for the info.
just a quick one tho, you say mark the body before i take the bootlid and doors off, how and where do i do this, could you just explain in a little more detail please as it sounds like quite a critical thing to get right....
thanks
Posted: Sun Feb 03, 2008 11:41 pm
by teamster1975
lorus5000 wrote:thanks for the quick reply, and thanks for the info.
thanks
Just make a mark around the outline of the hinges before you take anything off. It makes life a lot easier when you're lining up!
And support the bottom of the doors with a trolley jack & a lump of wood beford you take them off if you're doing it alone, and make sure you've got the window wound down so you can reach through to keep it balanced!!
Posted: Mon Feb 04, 2008 12:06 am
by lorus5000
thanks, will it be easy enoungh to link new electric windows in on new rear doors
thanks for timely advise
lorus
Posted: Mon Feb 04, 2008 12:05 pm
by teamster1975
If you've already got rear electric windows it's a piece of cake, it's all connected through the screw-in jack on the door.
If you haven't though you'll need to make up the loom to go the drivers door etc. It is possible, I converted my LX to GLX spec including all the electrics early last year.
