problem due to spitting dummy out!!!!!!!!
Posted: Mon Apr 28, 2008 9:08 pm
by dervpower
had a bad day today needed to be somewhere in a hurry and had a flat battery due to leaving lights on just sidelights though for a hour or so anyway slammed drivers door and now window only opens halfway any ideas? :oops:
Re: problem due to spitting dummy out!!!!!!!!
Posted: Mon Apr 28, 2008 9:38 pm
Has it jumped out of the track? You'll probably have to take the inside panel off to have a squint.
Posted: Mon Apr 28, 2008 9:43 pm
by biglamb
hmm, sounds like you have knocked the runners out of line. take the door card off and have a look. run the window up and down and see where it fouls. should be as simple as relocating it. This is assuming that the force of execcive slamming has dislodged somthing. then you need to fit a lights on buzzer. if you already have one, you need to listen to it.!! next time slam your fist into somthing hard and solid, and unbrakeable. Good look. let us know how you get on.
Posted: Mon Apr 28, 2008 9:46 pm
by biglamb
r steve, we were typing at the same time. with the same ideas. exept i have typing diarhiaa! and tend to type tooo much tooo often, people say i should stop talking and typing at least one sentence before i do. so not to go on too long waffeling crap. but i think they dont know what they are saying, what do you think? do i type too much, or am i too the point exactly. i dont think i waffle. or maybe ido, perhaps we will never know. who does know.
Posted: Mon Apr 28, 2008 9:54 pm
by dervpower
yeah wll have to take the door trim off and have a look are they a bastard to get off? i have a lights on alarm but i ignored it as id left the keys in the ignition and that gives the same buzzer but i wouldnt have thought it would flatten the battery on sidelights for an hour or so
Posted: Mon Apr 28, 2008 10:03 pm
by biglamb
no it should really get the battery flat. saying that. mine has a power saving cut off. if i leave the ignition on for too long, the car shuts down all none essential stuff, like radio and dvd player ect. get your battery tested. most motor factors and garages will do it for free.
Posted: Mon Apr 28, 2008 10:05 pm
by trem1
biglamb wrote:r steve, we were typing at the same time. with the same ideas. exept i have typing diarhiaa! and tend to type tooo much tooo often, people say i should stop talking and typing at least one sentence before i do. so not to go on too long waffeling crap. but i think they dont know what they are saying, what do you think? do i type too much, or am i too the point exactly. i dont think i waffle. or maybe ido, perhaps we will never know. who does know.
biglamb no offence meant but you talk shite at this time of night :shock:
Posted: Mon Apr 28, 2008 11:08 pm
by teamster1975
dervpower wrote:yeah wll have to take the door trim off and have a look are they a bastard to get off?
Easy peasy. Take off speaker grill & remove speaker, couple of screws to remove in handle (you have to pop cover off to reveal screw) and if memory serves another screw on the bottom (pop off cover again).
The door card is held on with push clips, work your way around slowly pulling to release them. Watch out you don't snag the wires for the switches!
Posted: Tue Apr 29, 2008 4:32 am
by STALLED
You checked the switches? Sometimes they pop out?
Posted: Tue Apr 29, 2008 6:35 am
teamster1975 wrote:Easy peasy. Take off speaker grill & remove speaker, couple of screws to remove in handle (you have to pop cover off to reveal screw) and if memory serves another screw on the bottom (pop off cover again).
You have to take the door mirror back cover off, it's held on with little clips and it's quite fiddly. Carefully ease off the surround for the door release, I think you might need to push it slightly either backwards or forwards (can't remember which, it's a while since I had my D8's off but I've done it on loads of other cars). I always miss something so don't give it brute force and ignorance To get the clips undone you're meant to use a trim tool but it's enough just to get your fingers behind the trim and give it a wee tug, start at the bottom. They often break, special tool or not, but they're actually quite cheap and Pug has probably got tonnes of the things. Disconnect the switches, the don't fit through the hole.
Posted: Tue Apr 29, 2008 2:40 pm
by teamster1975
steve_earwig wrote:You have to take the door mirror back cover off
I forgot that bit! The surround for the door release just pops off.
Posted: Wed Apr 30, 2008 10:35 pm
by dervpower
easy fix :cheesy: removed trim problem found to be large piece of insulation type stuff thats normally glued to the door skin had dropped off when i slammed door stuck it back then trim back on job done :cheesy:
Posted: Thu May 01, 2008 1:01 pm
by teamster1975
dervpower wrote:easy fix :cheesy: removed trim problem found to be large piece of insulation type stuff thats normally glued to the door skin had dropped off when i slammed door stuck it back then trim back on job done :cheesy:
Hope you used mega strength glue just in case you get angry with the car again dervpower! :P :lol:
Posted: Thu May 01, 2008 11:21 pm
by dervpower
im currently taking anger management courses!!!!! :cheesy:
