mjb wrote:That looks VERY smart! Bluey Bling on a silver car really does make a massive difference.
Not too keen on the exhaust and boot lip though
Its like most things some people like some people dont. Not a fan of big spoilers in any shape or form on a 406. Have always liked the lip type you find on a bmw so now it has one
With ref to the exhaust its only a trim. Its a standard sytem with an oval trim fixed over the end. Like most things look better in the flesh than on a pic. Thanks for your comments mjb
Thanks for all the positive feedback i like and thats the main thing
trem1 wrote:looks good
looks standard at first glance then you think hang on summats different
how exactly did you colour code the trim cos i'm thinking of doing it to my 407
As my mate puts in brings the 406 bang upto date
With ref to painting. The only advise i can give is spend as much time as possible on the preperation. I used plenty of acetone at first to strip the black plastic inserts of oil gel or what ever was used to make them shinny black. Decided not to remove the chrome inserts as its a bastard to do apparently.
I gave them a good rub over with some 180 grit paper paying attention to covering all of the black trim and chrome insert. Very time consuming
Then i masked off around the inserts with newspaper to avoid overspray. Applied a very thin layer of plastic primer let dry for a good 15 mins between 3 thin layers of paint.
Used some fine paper wet and dry 400 then 800 paper to smooth the surface.
Wiped dry and clean from water and dust.
Applied a very thin coat of paint let dry for a good 15 mins between 3 thin layers of paint.
Left car for 24 hours.
Repeated process above. Left for around 3 to 4 hrs. Then started using some very fine wet and dry started with 800 to 1200 and finished with 1500. So surface was nice and smooth ready for top coat of laquer.
Left paint for a good two weeks to harden. Then applied some cutting paste to finish off etc... It has lasted nearly a year the only problem is the front is chipping a little But hey lets face it it looks pretty good i.m.o.a.
