Steering Wheel Woes.
Posted: Thu Apr 23, 2009 11:42 pm
Got to love the 406, it's started falling to bits each time, I shut the door.
Anyways this is the current serious dangerous issue.
As my seat is all the way back being a big guy a 6ft 8, I need the steering wheel extended toward me ideally, although I can still reach it fine when the column is sat against the dash board.
Problem is when you undo the plastic latch lock thing, the steering wheel moves up and down, in and out and it should the lock it, it won't move up and down but it will still over in and out.
It's if you push it in which a bit of force.
So for example, do an emergency stop and brace on the steering wheel or strech out on a journey and push your arms on the steering wheel and bang it collapses back into the inward position near the dash and with a tug you can pull it back again without releasing the plastic lever, this is dangerous as I could lose control in an emergency braking situations or on the motorway when I'm streching out.
Any ideas
Any ideas
