Door Hinges
Posted: Sat Jun 06, 2009 10:40 am
by nimike
Anyone got any tips on how to grease these bad boys and what to use?
Mike
Re: Door Hinges
Posted: Sat Jun 06, 2009 11:41 am
by bangernom1cs
HI,
I use white grease aerosol or copper grease. Make sure you get a can with an extension straw
to get right in, especially the rear door check straps as these have rollers which sieze up rapidly.
Work them back and to a couple of times adding grease as you go.
There's many a 406 taxi with flappy back doors because of this.
My first D8 rear doors had never been opened hardly as it was a company car presumeably
with a 1 only driver as the seats were all perfect except the drivers. It took nearly 2 years of
greasing and everyday useage to get them to work correctly.
Getting the same prob now on my D9 too also.
T
Re: Door Hinges
Posted: Sun Jun 07, 2009 1:20 pm
by swiss
Yeah, my rear doors groan and complain no matter how much I grease and work the hinges, but again they don't get a whole lot of use
Re: Door Hinges
Posted: Sun Jun 07, 2009 1:57 pm
by eoin27
This should help alleviate the situation. Grease those bad boys up before installation and you will certainly have years of trouble free door opening pleasure
Re: Door Hinges
Posted: Sun Jun 07, 2009 6:48 pm
by swiss
Nice. I'll add two of those to the List ^_^
Re: Door Hinges
Posted: Sun Jun 07, 2009 7:05 pm
by jasper5
Hinges or checkstraps?
I find the best thing to do with hinges, is to spray a good dose of WD40 into the hinge and work the door back and forth until the door feels a little easier, then use some oil on them, working the door back and forth.
As for checkstraps, give them a real good greasing with multipurpose grease and work the door back and forth until you feel a difference, keep lots of grease on the sliding bits and the curved bit and you'll be fine.
The only time I have needed to change the checkstraps is when the strap has actually broken.
Re: Door Hinges
Posted: Sat Jul 18, 2009 8:49 pm
by skylinemv
Just had one of my rears pop the circlip and roller out due to lack of lube.
stripped it out and carried out a refit and re-grease. All okay :-)
