Rear light cluster replacement.
broadie777
Post by broadie777 »
My nice mot man failed the 2.2 sri 2000 model on a cracked rear light cluster.Managed to get a replacement is there anything i should watch out for when i replace the old one .
Many thanks
Re: Rear light cluster replacement.
It's a common leakage point; run a bead of clear silicon around the replacement before you fit it, other than that a pretty straight forward job!
turbolag
Officer of the law!
Post by turbolag »
He'll have only failed it if it's showing white light, so I guess it's pretty mullered?
Don't use silicone - it excretes water as it cures and this will remain trapped against the bodywork and can raise merry rusty hell. There are some proper sealers out there for the task, or if you're tight use some bitumen based drainpipe sealer.
turbolag wrote:Don't use silicone - it excretes water as it cures and this will remain trapped against the bodywork and can raise merry rusty hell. There are some proper sealers out there for the task, or if you're tight use some bitumen based drainpipe sealer.
I didn't know that, you learn something new everyday!
You mean that mucky old black gutter sealant? Good stuff but a sod to get off your hands! (White spirit time) :oops:
turbolag
Officer of the law!
Post by turbolag »
That's the gooey stuff chum. It's a bugger to apply but a wipe over the join with white spirit on a rag usually tidies it up nicely.
broadie777
Thanks guys sorted two 8 mill nuts that hold the headlight assembly need to be removed and bobs your uncle 2 min job.
many thanks
Chris
