OMG!!!!!!!
puglover
OMG!!!!!!!
Post by puglover »
just found out today that the sill on the passenger side is completely rotten between the front door and the rear door.....
basicly in the middle. :evil: :evil:
has anyone else had this problem ?
and can you get hold of new sills for them and how do you go about fitting a new on????
btw mines is a 97 lx 16v petrol
Re: OMG!!!!!!!
Never heared of rusty bits on 406s at all :shock: :shock: . Unless it's been changed before :? . The drainage holes in the sills sometimes get blocked resulting in the sills holding water, that wouldn't help. :?
Re: OMG!!!!!!!
It's probably had a knock some time and the water drain issue did the rest.
I looked on Servis Pox, you have to buy the whole side of the car...
No-one seems to be doing sills for the 406, so it looks like you'll have to ad lib it :? You could either get hold some sheet steel and fabricate a bit to replace the "missing" part, or find someone who's dismantling a 406 and doesn't mind you turning up with an angle grinder, remove the offending section and weld it in (much better than the "cover" sills we used to get, I'm sure they're weak as sh!t and if you had a wee shunt the car'd fold up :shock: ).
I suppose it depends just how much sill is missing, any chance of a pic?
puglover
Re: OMG!!!!!!!
Post by puglover »
thanks for your help... at the moment there are no pics as until i know what im gonna do to repair it i dont want to touch it if you know what i mean but a soon as i know and start proding and poking then ill put some piccies up
ianst28
2.2 16v
Location: sunny wirral (who am i kidding it's always bl&^%y raining)
Re: OMG!!!!!!!
Post by ianst28 »
just had a look at hadrians online catalogue they dont list sills for either the d8 or the d9 i'll keep looking and if i find anything i'll post it here
If at first you don't succeed, skydiving is not for you !!!!!
Re: OMG!!!!!!!
Best off welding something in, rather than tack welding a cover sill on it, IMO, unless you can get a decent continuous weld a la Dai Rees. If it's very near the B-post then you want it as strong as possible.
Always depends how big the hole is really, if it's only a couple of inches weld a plate in, grind it down and flatten it out with filler, if it's two feet, well, then you need a sill, either a section from a tin can cover sill or the relevant section from one in a scrapper. Preferably the latter.
eoin27
The Irish 406 addict
Re: OMG!!!!!!!
Post by eoin27 »
i think its time to get edd china on the case
Re: OMG!!!!!!!
I hate that guy. He makes everything seem so bloody easy! :cry:
Re: OMG!!!!!!!
I had to google him, he must be recent.
Re: OMG!!!!!!!
Mechanic guy from a TV programme called 'Wheeler Dealers' where they take used cars in varying conditions, do them up and sell 'em on. Roughly half the programme is Ed talking you through mechanical stuff
Re: OMG!!!!!!!
I know, I googled him :cheesy:
Cookies
Re: OMG!!!!!!!
Post by Cookies »
He's also the guy who makes those wacky cars out of beds and sheds and stuff - apparently!!!
