That's a badly knackered mount!Welly wrote:One of my front springs went at 9 years old/125K miles - has anyone ever seen the length of a standard 406 front spring? they're bloody huge![]()
And the diesel engine mounts take a lot of strain because of the torque - the engine is literally trying to do a 360 on it's axis.
Here's one I paid for earlier:
My new HDi...
- OdinEidolon
Re: My new HDi...
- DaiRees
- Site Admin
Re: My new HDi...
Well I'd have thought a bit of routine maintenance on the strut top bearing would considerably prolongue the life of the spring. Also, i'f you're going to change the springs, change the bearings too!
- OdinEidolon
Re: My new HDi...
You know, this is my first car and everything I've not changed or repaired yet is completely new to me, a lack of knowledge I plan to make up with time.DaiRees wrote:Well I'd have thought a bit of routine maintenance on the strut top bearing would considerably prolongue the life of the spring. Also, i'f you're going to change the springs, change the bearings too!
So recapping:
- my spring(s) could fail anytime
- there's no way to diagnose if they are going to fail soon
- they are definitely not cheap
Could you please point me to some SB part numbers for these bearings? I've never worked on any suspension setup so I know nothing about it (yet)!
Thanks guys. And sorry Bailes.
Re: My new HDi...
Just for info Sam, I got a quote from Celtic Tuning when I first got the car, didn't follow it up and hey-presto a cheaper quote arrived a month or two later, - £50 less, IIRC.Bailes1992 wrote:Right a little digging...
The Siemens sid80 ECU CAN be remapped, it does NOT have to be removed from the car.
GotBoost down by me have quoted £225+vat for a stage one tune ~120bhp.
Waiting for Celtic tuning to get back to me, but their maps are more like 130bhp and 290nm's of torque! So depending on price, and weather ot not they remap Siemens ECU's will depend who I'l go with, if I map at all!
Also my throttle issue, guy on TDOC just diagnosed a worn throttle position sensor, just ordered a second hand one off ebay for £20 to see if it is the problem. Apparently quite common.
- DaiRees
- Site Admin
Re: My new HDi...
Sorry mate, I don't have SB at the moment but I'm sure someone else will oblige.OdinEidolon wrote:Could you please point me to some SB part numbers for these bearings? I've never worked on any suspension setup so I know nothing about it (yet)!
Also, bear in mind that this is just 2nd hand information, I've no personal experience of this either way, but it certainly appears to make sense that the 2 things are related.
- highlander
- PowerFlow Shill
Re: My new HDi...
No idea about official Pug costs for replacement springs, but here are some after-market (non-lowering) front springs I found on eBay:OdinEidolon wrote:So recapping:
http://www.ebay.co.uk/itm/330634867889
Never heard of the company, no idea what the products are like, but that's not what I'd call expensive.
And here are the bearings I found:
http://www.ebay.co.uk/itm/280739834473
Hope this helps
- OdinEidolon
Re: My new HDi...
Thnaks anyway mate, I'll do some research later maybe.DaiRees wrote:Sorry mate, I don't have SB at the moment but I'm sure someone else will oblige.OdinEidolon wrote:Could you please point me to some SB part numbers for these bearings? I've never worked on any suspension setup so I know nothing about it (yet)!
- OdinEidolon
Re: My new HDi...
Thanks HL, you always are spot on!highlander wrote:No idea about official Pug costs for replacement springs, but here are some after-market (non-lowering) front springs I found on eBay:OdinEidolon wrote:So recapping:
Hope this helps
Re: My new HDi...
The springs that Highlander linked to are widely used in the trade, the price is slightly less than I would pay as a trade price.
The quality is usually pretty good, but I've had a couple for other cars which have been a difficult fit due to being made slightly different than the original (slightly wider, not sitting in their mounts properly).
Regarding the top mounts...I usually open up the bearing case and inspect the inner bearing race, I'f the bearing race has any damage then I replace them(I rarely have to replace them).
I usually soak the bearing race in oil for a short while and pack the race with lots of grease, that usually sorts out any worries with the top bearings.
Replacing the springs is a very difficult job as compressing the springs is a tricky and potentially dangerous job...I take these type of springs to my mate who has a hydraulic spring compressor to replace them....much safer....as has been noted above, the springs are much bigger than their compressed length hence the difficulty in compressing and fitting.
There is another make widely used in the trade which are good quality, these are FAI.
- OdinEidolon
Re: My new HDi...
Brilliant info there Jasper, thanks. Do you believe I should inspect the bearing before deciding if I should replace the springs? Is there a way to know when they're fonna fail?jasper5 wrote:The springs that Highlander linked to are widely used in the trade, the price is slightly less than I would pay as a trade price.
Re: My new HDi...
It's a bit difficult trying to predict when they will fail but look to see if the springs have any serious corrosion on any of the coils.
Without removing the shock absorbers or springs you can check if the bearings are moving smoothly by getting someone to turn the steering from lock to lock and watching each spring in turn to see if the coils are sticking or winding up.
If the springs do not move when the steering is turned lock to lock then there is a good chance the bearings are moving freely.
- OdinEidolon
Re: My new HDi...
Will do, precious advice Jasper, brilliant, thanks!jasper5 wrote:It's a bit difficult trying to predict when they will fail but look to see if the springs have any serious corrosion on any of the coils.
- Bailes1992
Re: My new HDi...
Celtic tuning wouldn't remap my car using the mobile service, I would have to give my car to a company in Bristoll. Apparently it's hard to remap these cars with the comms port. The ECU may have to be removed but not dismantled.Doggy wrote:Just for info Sam, I got a quote from Celtic Tuning when I first got the car, didn't follow it up and hey-presto a cheaper quote arrived a month or two later, - £50 less, IIRC.Bailes1992 wrote:Right a little digging...
- Bailes1992
Re: My new HDi...
New throttle position sensor fitted today, what a difference
Can actually maintain 80mph without having my foot to the floor
Service will hopefully get done tommorow!
Then goto get my mechanic to sort out my squeeky AUX belt and my wheel alignment.
And then all thats left to change is the brake discs and mechanically the 406 will be perfect... for a few days at least
- Bailes1992
Re: My new HDi...
Urrghhhh
Oil came out black and like tar! Going to leave it 500 miles and drop it again to try clear all the crap!
