Gaz's 1.9 Turbo Diesel
Re: Newer Pics Of My 406 1.9 TD
ye could do , what would it do that never heard of that being done before 8)
Bailes1992
Post by Bailes1992 »
Gary406 wrote:ye could do , what would it do that never heard of that being done before 8)
The standard earth has to put up with your new amps plus what it was originally designed for. Giving it a second earth eases off the strain on the standard earth :cheesy: Should help your dimming issue :)
the amps are earthed individually tho 8)
Bailes1992
Gary406 wrote:the amps are earthed individually tho 8)
Straight to the battery?
no , my earth cables from the amps are half a meter long and bolted to the floor in the boot 8)
Bailes1992
Gary406 wrote:no , my earth cables from the amps are half a meter long and bolted to the floor in the boot 8)
Yeh but the earth cable going from the battery to the cars chassis is only designed to take the power from the standard car equiptment and isn't adiquite for the amps which is why it's dimming :)
ye i get you, i might give that ago cheers mate 8)
ashwood trim now fitted to front only
doorcards spray died with fabric paint (this stuff is amazing but expensive)
BEFORE
AFTER 1 COAT STILL P1SS WET THROUGH
Will post more pics with 2 coats 2moro once dry and its daytime to get a better pic
Gary406 wrote:ashwood trim now fitted to front only
Are you planning on getting one of these in there?
http://cgi.ebay.co.uk/PEUGEOT-406-COUPE ... 4cf4744748
Don't think there's much else you can do inside there once the doorcards are on.
That is unless you manage to find a set of seats like mine...
why will a coupe leather wheel fit in my saloon ?
Easily. My leather wheel came from a coupe. Mine is slightly smaller though, so may be worth getting a wheel & airbag together.
i asked about D9 wheels fitting into D8s they said no
of it a coupe different alltogether ?
You get D8 and D9 Coupe's as well; the exterior differences are much more subtle than they are on the saloon/estate though. A pre-1999 Coupe will be a D8.
The D8 Coupe wheel should fit on to a D8 saloon/estate, and vice versa, just as long as the horn trigger is on the same place on your car as it is on the donor (i.e. your horn is on the stalk, so must the horn be on the donor)
ok thanks, think i will next invest in a leather wheel then :mrgreen:
