Page 5 of 26
Re: Newer Pics Of My 406 1.9 TD
Posted: Thu Nov 11, 2010 5:14 pm
by Gary406
ye could do , what would it do that never heard of that being done before
Posted: Thu Nov 11, 2010 5:15 pm
by Bailes1992
Gary406 wrote:ye could do , what would it do that never heard of that being done before
The standard earth has to put up with your new amps plus what it was originally designed for. Giving it a second earth eases off the strain on the standard earth
Should help your dimming issue
Posted: Thu Nov 11, 2010 5:24 pm
by Gary406
the amps are earthed individually tho
Posted: Thu Nov 11, 2010 5:25 pm
by Bailes1992
Gary406 wrote:the amps are earthed individually tho
Straight to the battery?
Posted: Thu Nov 11, 2010 5:26 pm
by Gary406
no , my earth cables from the amps are half a meter long and bolted to the floor in the boot
Posted: Thu Nov 11, 2010 5:28 pm
by Bailes1992
Gary406 wrote:no , my earth cables from the amps are half a meter long and bolted to the floor in the boot
Yeh but the earth cable going from the battery to the cars chassis is only designed to take the power from the standard car equiptment and isn't adiquite for the amps which is why it's dimming
Posted: Thu Nov 11, 2010 5:31 pm
by Gary406
ye i get you, i might give that ago cheers mate
Posted: Wed Jan 12, 2011 6:32 pm
by Gary406
ashwood trim now fitted to front only
doorcards spray died with fabric paint (this stuff is amazing but expensive)
BEFORE
AFTER 1 COAT STILL P1SS WET THROUGH
Posted: Wed Jan 12, 2011 6:33 pm
by Gary406
Will post more pics with 2 coats 2moro once dry and its daytime to get a better pic
Posted: Thu Jan 13, 2011 10:37 am
by waue1978
Gary406 wrote:ashwood trim now fitted to front only
Are you planning on getting one of these in there?
http://cgi.ebay.co.uk/PEUGEOT-406-COUPE ... 4cf4744748
Don't think there's much else you can do inside there once the doorcards are on.
That is unless you manage to find a set of seats like mine...
Posted: Thu Jan 13, 2011 10:57 am
by Gary406
why will a coupe leather wheel fit in my saloon ?
Posted: Thu Jan 13, 2011 11:15 am
by waue1978
Easily. My leather wheel came from a coupe. Mine is slightly smaller though, so may be worth getting a wheel & airbag together.
Posted: Thu Jan 13, 2011 11:35 am
by Gary406
i asked about D9 wheels fitting into D8s they said no
of it a coupe different alltogether ?
Posted: Thu Jan 13, 2011 11:41 am
by highlander
You get D8 and D9 Coupe's as well; the exterior differences are much more subtle than they are on the saloon/estate though. A pre-1999 Coupe will be a D8.
The D8 Coupe wheel should fit on to a D8 saloon/estate, and vice versa, just as long as the horn trigger is on the same place on your car as it is on the donor (i.e. your horn is on the stalk, so must the horn be on the donor)
Posted: Thu Jan 13, 2011 11:42 am
by Gary406
ok thanks, think i will next invest in a leather wheel then
