Wait... you had a clock
and aircon? How does that figure spec-wise
Anyway, the slightly less-than poverty spec D8s like my LX had (from left to right) a fuel gauge, rev counter, speedo and water temp. So what you want (unless you expressly wanted the higher-spec panel) is a cluster from a deceased LX.
But yes, if they needles have come off at some point they'll never go back on quite the same. I had to remove my needles to turn my dash lights blue. To get them back on (more or less) correctly... well, I knew where the engine idled, for the rev counter, and I took a guess at where the fuel was. The water I knew would stabilise at 80, and the speedo... well, it was the satnav method as described above ^_^
