HDI 110 Estate Modifications!
Posted: Thu May 07, 2015 12:16 am
Here it is in all its glory. A lot of car for £900 really. FSH and one lady owner. (Probably why there was nothing left on the clutch when I got it
) Can you spot the elephant in the room? 8-)
Bit filthy after the snow and salty roads.
Now for the modifications
Simota closed filter to try liven up the noise of the engine. Still sounds standard just a bit more interesting if that makes sense. No crappy open cone filters there, don't want to loose out on any power. It follows the path of the original system, being more directly and a bit shorter. Yes I ran out of hose clips so i used the almighty cable ties. This modification cost me nothing as a already had all the bit from previous cars.
True yorkshireman showing through again, Free JVC speakers and an amp I had laying around. Having said that the standard Harmen sound system is pretty good.
Ops...
Yeh we don't need this scrap.
Some £25 polish steel and We are on our way to less turbo lag and more top end.
Removed this scratty plastic undertray. Can you guess why?
A nice break from the terrible weather provided me with time for some little touches. Fly-eye treatment on the lights and a subtle tinted sunstrip. Heko wind deflectors finally fitted after some trouble with the electric windows.
I have removed the chrome trim from the bumpers too which I am going to plasti-dip.
Now for a tasty update, A 3mm thick hunk of sheet steel I have been working on and a nice delivery from postman pat. I think you can now see where I am going with this one...
Oh dear, the top mount bearings literally disintegrated upon removal, only the compression from the springs holding them together. I guess these need replacing...
The result?
Plain Jane not so plane anymore.
Ops...
The result?
