Page 2 of 5
Re: My GTX
Posted: Tue Mar 13, 2018 5:40 pm
by Doggy
Ouch!
On a brighter note, with that there MFD, it's just a question of prodding the two buttons either side to set everything.
(Can't honestly remember which does which as it's about 6 years since I touched one, but it wasn't difficult).
Keep up the good work.
Re: My GTX
Posted: Tue Mar 13, 2018 7:29 pm
by caprixpack
I'll give it a go tomorrow. As for the radiator and hose, I've seen some bad car design in my life but this has to be one if the worst I've seen. It's bloody atrocious, who thought push fit water connectors on a car would be a good idea.
Re: My GTX
Posted: Tue Mar 13, 2018 7:40 pm
by GingerMagic
Just wait until you need to change a rear abs sensor, or remove the lift pump.....
You will learn new ways to string together swear words...
Re: My GTX
Posted: Wed Mar 14, 2018 1:48 pm
by caprixpack
Well all I can say is I'm very surprised. After phoning ecp GSF and Peugeot yesterday afternoon and none of them being able to get me a bottom hose, I found one on eBay for £28 with free postage. Pulled the trigger and was expecting a fair wait but this just arrived.
Looks to be pretty good, I'll bung it on and see how it goes.
Re: My GTX
Posted: Wed Mar 14, 2018 4:28 pm
by caprixpack
Following on from earlier.
The new hose fits, just. It's incredibly tight over the top fitting but with some persuasion it went on, and the bottom fitting actually seals.
Bleeding the system is a bit bloody long and drawn out with three bleed points, but I got there eventually.
Also I found a rear wiper arm at a local breakers and managed to sort the clock and temperature display.
Re: My GTX
Posted: Wed Mar 14, 2018 5:44 pm
by GingerMagic
That's a good result, those lower rad pipes are like rocking horse poo.....
Thing is with the older 406 (and other cars to be fair) is that the owner puts off one little job, then something else crops up and that is put off too - before you know it the list of problems is huge and the owner decides to sell. New owner has a bargain, and a good basis for a project given a bit of time and determination
Good work so far.
Re: My GTX
by Doggy
Well done, good progress there.
Re: My GTX
Posted: Wed Mar 14, 2018 6:53 pm
by caprixpack
Thanks. I think that's all the mechanical stuff sorted out, going to start on the bodywork next. I'm struggling to find the bit of trim on the tailgate above the number plate and the paint work is a bit of a mess. Although I have sorted the steamy headlight, and changed the fuel filter while all the pipes and cover was off.
Re: My GTX
Posted: Sun Mar 18, 2018 7:36 am
by caprixpack
Well I had set the weekend aside to give the GTX a bloody good clean but it looks like the weather has other ideas
Re: My GTX
Posted: Mon Mar 19, 2018 7:33 pm
by caprixpack
Another update. After the bloody thing chucking 2lt of water out the other day and replacing the broken seal in the expansion tank cap I was still not happy with how it was. So today I took the thermostat out and placed it in a pan of boiling water, it only opened about half what it should. So a trip to ecp and a new one was fitted. I went through the bleeding nonsense again and hopefully things will be sorted.
Re: My GTX
Posted: Mon Mar 19, 2018 10:56 pm
by Doggy
Hopefully that's it sorted now.
I remember the frustration and nagging doubts about airlocks from changing my water pump about 3 years and 70k ago -
which means it's due again soon.
Re: My GTX
Posted: Tue Mar 20, 2018 12:06 pm
by caprixpack
I feel like such a child, but I saw this on a local Facebook selling page for £5 so I bought it.
Not sure where I'm going to mount it yet, most likely just under the cruise control button.
Re: My GTX
Posted: Tue Mar 20, 2018 12:47 pm
by Doggy
Qu'est-ce que c'est?
If that's a boost gauge, I'd keep it out of sight, I understand the millennials tend to 'Blutoof it t'ya fone'
Re: My GTX
Posted: Tue Mar 20, 2018 1:10 pm
by caprixpack
Yeah it's a boost gauge, as for the Bluetooth nonsense you can't use your phone while driving so seems a bit pointless? Like I said I think it's going to be going under the cruise control button on the drop down panel that covers the fuses.
Anyway I gave the GTX its first wash in 4 years, sitting under a tree for all that time certainly hasn't done the paint any favours.
It's going to need a going over with a clay bar then I'll get the dual action polisher on it.
Re: My GTX
Posted: Fri Mar 23, 2018 11:42 am
by caprixpack
Well I thought everything was OK but I'm still having trouble with the bloody thing. The bottom hose is leaking and won't seal, I've tried a new seal still leaks a bigger seal and it still leaks. It's just a piece of sh*t design, who thought a push fit connection on a radiator was a good idea. I'm just glad it's not a car I rely on.
