My white 96 ,1.9td
Re: My white 96 ,1.9td
Why did you scrap it?
- ddoherty406
It was hit at the front and needed a new panel welded in so that the lights could be aligned, the jack went through the cill as it was rotton so it needed replaced. Also needed new brake disks and pads and the pipes redone as they were pitted. Timing belt and aux belt were due to be replaced. They are just the main points, it wasnt worth putting the money into a car with such high miles.
