FRONT COIL SPRINGS
- 1.8 8v
FRONT COIL SPRINGS
Hello,
have recently replaced both front coil springs. Did not use Peugeot springs, used Spurious parts made by KYB Europe. The cars wheel arches are now about 4/4.5 inches above the tyres, the KYB part numbers match for the Peugeot 406 Hdi model and year, yet the car looks a little odd now they are fitted. Have had the job re-checked by another mechanic, could find nothing wrong in the way they were fitted. Anyone recommend spurious springs or must they be Peugoet O/E to cure this problem?
Thanks for any replies,
regards,
Tonyredz.
regards,
Tonyredz.
Re: FRONT COIL SPRINGS
sometimes the springs have to bed in. give it a couple of weeks and see if the car settles down,but it does seam very high
I've been looking at the KYB coil spring catalogue and it does seem very confused, I guess the probability is that they're the springs for a V6/2.1td.
If they're not put me down for a full set
KYB stuff is very good.
Check this thread and measure your own ride-height...viewtopic.php?f=5&t=3822&hilit=ride+height#p36477
- TRAVIS BICKLE
- 2.0 Turbo
I agree ive used KYB stuff on jap stuff, its good quality.Welly wrote:KYB stuff is very good.
98, Executive turbo estate in aluminum silver. The stealth wagon! Now departed, New project Xsara VTR-8 in progress, Next Project, 406 D8 / JAP. So will be looking for a 406 again when the xsara is done!
- plod
I had the same issue when replacing my springs, but as said above, give a little time and they'll settle down
1999 D8.5 HDi GLX - Sold
Bring back my 406
- 1.8 8v
Was hoping they would settle, replaced the springs about 7/8 weeks ago, & they've not moved at all..plod wrote:I had the same issue when replacing my springs, but as said above, give a little time and they'll settle down
- 1.8 8v
Thanks Welly, will try this, thanks for your reply regarding my oil change blunder as well.Welly wrote:KYB stuff is very good.
will probably take longer than that , i replaced my springs about 8 month ago and its still high not as high as when new but its settlingtonyredz wrote:Was hoping they would settle, replaced the springs about 7/8 weeks ago, & they've not moved at all..plod wrote:I had the same issue when replacing my springs, but as said above, give a little time and they'll settle down
- 2.0 Turbo
pity the catalogue isnt a bit easier to use
Replacement !
