3 inch lowered springs 406 1.8i 1998
Is it possible to fit 3 inch lowered springs with the standard shockers,got a broken spring a been offered the springs as a freebie and will need to strip the suspension down to replace some worn links etc so if these would fit i would stick them on.
1997 D8 1.8I STILL GOIN!
1996 MERC C200 ONGOIN PROJECT HONEST!
1995 ESCORT DIESEL VAN
2009 DAF XF 105 460BHP
THE PARTY AINT OVER YET !!
- plod
Re: 3 inch lowered springs 406 1.8i 1998
I believe 40mm is the lowest drop you can do with the standard shockers so 3" (75mm) is too much i'm afraid
1999 D8.5 HDi GLX - Sold
Bring back my 406
Thanks Plod,didnt think i had enough travel on the standard shockers just checking.
75mm lower ? really ?
you must have a lot of money to keep replacing exhaust when it keeps getting ripped off
- lozz
if you live in area with no speed humps bad holes in road etc, you can get away with having them low,
ihad a fiat that ilowerd and ended up driving over speed humps at an angle or it wouid get caught up on the undertray
it was fun while it lasted,
adjustable coil overs are the way to go ithink
- Hangar18
3 I N C H E S!!??
I rub speed bumps standard!!
1996 406 Executive XU10J2CTE
1995 405 GLX XU7JP
1995 405 GLX XU7JP
