Hi All, I have developed a knocking when turning the steering wheel. On investigation I find the knock is coming from the front nearside suspension strut., looking from the top where the upper mounting bolts are ( with bonnet open ) I can see that when I turn the steering wheel it is trying to turn the strut and it clicks back and I get a click click, click ( or Knock ).
Anyone had this problem? Is it serious? Is the strut Knackered??
Any help would be really useful.
Thanks Guys in anticipation
Peogeot 406 Hdi
2001saloon
Knocking on Steering
- lozz
Re: Knocking on Steering
Ihad that on a pug 306,
aclunk when you turned the steering wheel,
it was a Weak spring, ijust went to breakers yard and got a complete strut with spring, swapped it over, saves time and a few quid,
jonti007 wrote:Hi All, I have developed a knocking when turning the steering wheel. On investigation I find the knock is coming from the front nearside suspension strut., looking from the top where the upper mounting bolts are ( with bonnet open ) I can see that when I turn the steering wheel it is trying to turn the strut and it clicks back and I get a click click, click ( or Knock ).
Peogeot 406 Hdi
2001saloon
Sounds like the top bearing/mounting.
