Knocking suspension :(
- dukey406
Having a bit of bother with the 406 and not had time to look at it yet. When manouvering such as parking where you use full lock on the steering, there is a loud metallic knock. It isn't rotational but sounds quite heavy, does andone have any idea?
- Ares
Re: Knocking suspension :(
i have similar sound when im driving and passing on some holes,but i think that the main reason for this is the fact im lowered.
Check the shock absorber system
- 2.0 Turbo
If it's happening only on full lock, and it isn't rotational, then I would worry that the top mount bearings are on their way out. A common problem on these cars. If the bearing is seized then the spring gets twisted as you turn the wheel and can jump in its cup. If this is the case, you have a very real risk of snapping a spring, get it seen to before this happens then all you have to replace are the bearings. If you are replacing a spring then you should really be replacing both sides, and if you replace a spring then you will also need wheel alignment, so the whole job becomes a lot more expensive. On top of that a spring can damage other items when it snaps, like brake pipes and even the tyre.
- dukey406
You were exactly right. The top mount was siezed partially and the top 3rd of the spring had snapped off and got twisted with the rest. Replacement strut assembly of eBay for £30 has got me sortedally406 wrote:If it's happening only on full lock, and it isn't rotational, then I would worry that the top mount bearings are on their way out. A common problem on these cars. If the bearing is seized then the spring gets twisted as you turn the wheel and can jump in its cup. If this is the case, you have a very real risk of snapping a spring, get it seen to before this happens then all you have to replace are the bearings. If you are replacing a spring then you should really be replacing both sides, and if you replace a spring then you will also need wheel alignment, so the whole job becomes a lot more expensive. On top of that a spring can damage other items when it snaps, like brake pipes and even the tyre.
- dukey406
Luckily no other damage. Got a replacement strut from a breakers from same vehicle, fitted today along with new droplink and car is nice and smooth also the slight left hand pull on the steering has gone
- Ares
Glad you sorted all out mate,another 406 mystery solved.
