advice on caliper overhaul kits needed
- 2.2 16v
I have a 2001 hdi 110 saloon , its done 165k
Its time I got the calipers all round overhauled , as I 'm getting sick of the squeeling, rubbing sounds around the car.
Does anybody know of a good place to get overhaul kits from including the pistons, sliders etc, also looking on the interweb there seems to be 2 types which could be fitted to my car ??? ATE and ?????
Any advice much appreciated
price of remanufactured calipers seems high !!
Re: advice on caliper overhaul kits needed
I bought a new set some years ago - cost £75 for the pair - I just put some plastilube under the sheathes to keep the sliders from sticking
https://rover.ebay.com/rover/0/0/0?mpre ... 2354111039
I couldn't find any prices on the site Steve posted about, maybe because I'm using my phone....
I think the overhaul kit was about 25 quid, with all the seals and rubbers etc for 2 callipers
That's a good price.
Truthfully I fitted the new ones, then got the old ones sliding thanks to a hammer and a vice, then lubed them up and sold them on
- 2.2 16v
thanks for the info guys, think I'm going to fit the new rears for £83. free postage (no returning old ones as they are new) and as you say you can free the old ones and poss sell them on !
trying to find front ones ?? for a good price ??
- 2.2 16v
update:
Had the car booked in to get the brakes sorted tomorow, just got the car started in car park when finished work tonight and CRACK, the car is going nowhere !
front spring snapped, had to get it recovered to the garage. to get that sorted as well !!!
Bad luck.
It does happen occasionally. The quick/dirty fix is a 2nd hand strut from a scrappy.
That is bad luck, but I've only ever know a spring to fail when stationary. Get the garage to look at the strut top bearings as when these start to fail then the stress of the front wheels turning is taken by the spring, not the bearings - leading to them snapping.
It won't happen when the car is moving as there is much less resistance.
It's a pity, but at least it can be done in one visit
- 2.2 16v
Not good:
when n/s spring snapped it did some damage it needs: drop link, drive shaft boot, flexi brake pipe, top bearing/mount (most of ball bearing fell out) ,
getting the other spring done as well !
so with the cost of getting the the brake bits fitted as well, I'm looking at decent sized bill !
The joys of motoring
- 2.2 16v
total cost £380 lets hope it was worth it?
both strut top mount bearing nakt, most likely caused spring failure
So work done :
new strut top mounts / bearings (both)
2 new springs
drop link n/s
driveshaft boot
flexi hose n/s
supplied parts:
2 new rear calipers + pad pins
2 rear drop links
new pistons & seal kit for front calipers
not a bad price for the work done I think
car back on form , no noisey brakes
So work done :
2 new springs
drop link n/s
driveshaft boot
flexi hose n/s
supplied parts:
2 rear drop links
I think that is a very reasonable price - about £1 per day over the year to have all that work done - excellent
