Abs Fault
Abs Fault
Hi first timer here,abs light staying on just changed front discs pads.worn to excess light still stays on,bit of judder first time i press pedal then light goes off comes back on and doesnt judder anymore,any ideas tips,love the site by the way.
- Captain Jack
Re: Abs Fault
Could be a loose connection under the drivers seat. Make sure all of those are in properly.
- Site Admin & Mad Biker!
Re: Abs Fault
You sure you're not thinking of the airbag light CJ?Captain Jack wrote:Could be a loose connection under the drivers seat. Make sure all of those are in properly.
I'd take the wheels off again and check that the brakepad wires are pushed well into the connectors; may be worth giving them a clean out.
Welcome in btw!
- Captain Jack
Re: Abs Fault
Duh! Ignore me....
Re: Abs Fault
Could have disturbed the ABS wiring and sensor - the sensor 'looks at' the teeth rotating on the driveshaft hub/ring. It's been known for this toothed ring to separate and cause trouble.
Re: Abs Fault
Sorry guys forgot to say the light was coming on before i changed brakes,thought it might of been due to the pads being right down,once the pedal been pressed the brakes are fine just want to get it sorted without the dealer price tag having had two 306"s swore never to buy a pug again here i am ready to part with more wedge.
Re: Abs Fault
If the ABS light comes on after the engine is started but before moving off then it is an electrical fault, probably an open circuit wheel sensor, but if the light waits until the wheels are moving or the breaks are applied the problem is with a broken ring, missing teeth or debris around the sensor.
If it is the latter then a good set of eyeballs will find the culprit.
99 HDi Estate 110 fast approaching 200K. edit: now 215K
Re: Abs Fault
Many thanks, will have the wheels off again that sounds like the problemwill let you know how it goes .
