Now I noticed the left hand wheel on my car has a dam sight more camber than the other wheel? Not I've had all the rear suspension looked at and all the bushes have been changed and wheel alignment was done. BUT the left hand wheel still has more camber? Now I saw two other 406 estates exactly the same? Is this normal then?
Ta, bailes.
Rear wheel camber?
- Bailes1992
Rear wheel camber?
- DiscoPol
- Shiny New C5 2.2 Bi-turbo!
Re: Rear wheel camber?
are we talking rear nearside, if so my estate is like that too, couldnt work out if it was an optical illusion, but when i jacked it up last time i checked and there was a good amount of travel top to bottom so im guessing its the rear bushing that is goosed along with the rest of it
but the near offside was fine, no movement at all, hmm go figure
Polski
Polski
- Bailes1992
Mines exactly the same but all the bushes are perfect and brand new ?Polskipug wrote:are we talking rear nearside, if so my estate is like that too, couldnt work out if it was an optical illusion, but when i jacked it up last time i checked and there was a good amount of travel top to bottom so im guessing its the rear bushing that is goosed along with the rest of itbut the near offside was fine, no movement at all, hmm go figure
Polski
