springs for diff cars
Posted: Sat Sep 18, 2010 11:32 am
by modified406
hi guys has any one tried lowering springs from another car to fit on the rear of the 406
Re: springs for diff cars
Posted: Sat Sep 18, 2010 11:38 am
by modified406
i may get bad comments about this idea but what about cutting the lowering springs on the back so there a little bit lower
Posted: Sat Sep 18, 2010 11:47 am
by HimBigChief
I've heard that Saxo front springs may fit in the rear of the 406, but I haven't given it a proper check myself.
Posted: Sat Sep 18, 2010 11:52 am
by Bailes1992
I know 306 front struts are used with standartd 306 springs to lower the front of a 406. But then 306 use a rear torsion beam? Hmmm :(
Posted: Sat Sep 18, 2010 11:54 am
by modified406
i read saxo springs fit the rear of the 406 but dont wont to waste 40 quid on a set of 60mm springs if they dont fit
Posted: Sat Sep 18, 2010 12:27 pm
by mjb
There's fitting and then there's able to support the weight. I reckon they'd probably just bottom out straight away with the weight of a 406 on them
Posted: Sat Sep 18, 2010 1:01 pm
by HimBigChief
Not too sure whether they'd bottom out as they support the front end of the saxo with the weight in and the lighter back end of the 406, so they'd probably to be more or less the same. From memory though, I'm sure the saxo front springs are much larger diameter than the rear springs on the 406. Coilovers are the way to go, or air ride if you've got far too much money.
Posted: Sat Sep 18, 2010 3:23 pm
by modified406
i wish i knew someone with a saxo so i could see the front springs lol
Posted: Sat Sep 18, 2010 3:47 pm
by modified406
Posted: Sat Sep 18, 2010 7:07 pm
by HimBigChief
any idea if this 60mm is for the rear http://www.europerformance.co.uk/pages/ ... ct=3913328
60mm front, 40mm rear.
would these fit the 2.0l hdi http://www.europerformance.co.uk/pages/ ... =555603503
Yes, but they may lower it more than the 55mm said.
Posted: Sat Sep 18, 2010 7:46 pm
by modified406
kl going to buy the 2nd ones i only need the rear springs from them as i want my bk end leveled out on the 406
