When we had the 406 about 7 months ago it had new pads fitted all round, now im just wondering now long they will last for (we decided to go for the premium ones if that makes a difference)
The car is mostly doing stop-start (urban) miles now..
thanks
new brake pads front and rear
Previous Car: S reg 406 SRi 2ltr Turbo - Petrol with 109,000 on the clock
Current Car: Renault Megane 1.6 16v Sport Coupe with 89,000 on the clock
Re: new brake pads front and rear
it all depends on the driver .. how hard you press , how late you press them
if you drive sensible and brake well in time they should last a good while,
its when you drive fast.. brake late and hard that start causing problems like warped disks
how long is a piece of string?xero01uk wrote:When we had the 406 about 7 months ago it had new pads fitted all round, now im just wondering now long they will last for (we decided to go for the premium ones if that makes a difference)
thanks
also did you change the discs?
- DiscoPol
- Shiny New C5 2.2 Bi-turbo!
I think they will last till they are gone.
So far the discs and pads on mine have lasted just over 34k and they where on it when I bought it.
407 GT multimedia
no i didnt change the disks as we couldnt afford them at the time
maybe your disks are worn so they will wear the pads quicker.
Current car - Ph3 1.8 306
Mine,the front discs and pads were changed a few months before i bought it and i had done 40k up to a few months ago and there was still meat left on the pads but a sticky caliper resulted in one pad wearing slighty more so for £50 for quality discs and pads i stuck em on and needed a slider which had seized,got a second hand caliper for £25 and used the slider,perfect now........renewed the rear discs and pads also.
I would describe my driving style as sedate
as said depends how you drive how long they last.
