Track rod
Posted: Tue Jan 11, 2011 8:39 pm
by karlosantana
Anyone got a picy of one? I've looked at it from below....mine's rusted solid need to work out how to take it apart
Side note: Mot coming up in 10 days nead new sills, tyres, heater blower windscreen wipers...it goes on!
Re: Track rod
Posted: Tue Jan 11, 2011 9:33 pm
Parts diagram any good to you?
Re: Track rod
Posted: Tue Jan 25, 2011 8:26 pm
by karlosantana
Awsome stuff!
Cheers!
Re: Track rod
Posted: Tue Jan 25, 2011 8:30 pm
by omega
i would give it a good soaking it plus gas a couple of times before going to do it to give youreself a better chance. split the ball joint then "undo" the nut.you will proplery have to hold the rod witha set of stilsons/mole grips.
wipers are straight forward but awkward, unless you need to remove the arms then you will need a puller.
heater moteris under the glove box 3 bolts and a couple of electrical plugs and its done.
Re: Track rod
Posted: Tue Jan 25, 2011 9:13 pm
by karlosantana
Done it all mate
god I'm good
, thanks to all!
Kyle
